MIx of diferent Signals
Less I am using my carbonite in HD 1080i format and I have several signals that are SD NTSC them I need to know how can I use this signal that appears in the output as equal format with the same dimension in the screen.
Let me know
There are 6 FSFC (found on the second page of the REF Menu) you select 1-6 then click on the knob to edit. You can assign them to any input you would like and then set how you want the Aspect handled.
But there is any form that I can use more that 6 FSFC because maybe I will have to mix nmore that 6 signal that are in SD.
Let me know
There is a Bus mode that you can enable instead. This will allow you to assign the FSFC to a Bus (in pairs). So you could assign 2 to the PGM/PST bus. Any source you select on PGM or PST will result in it FSFC that source if needed (everything gets FSync but on SD sources would get FC). If you assign a pair to to a Keyer then you will get the sources in that keyer FSFC as well.
However this will result in the sources not being FSync or FConverted in the MV as inputs – only viewable in the PV or PGM buses.
Can you explain to me how can I asign a FSFC to a bus. I have more thn 6 signl that I have to convert and I need to know how can I asign.please send me the instruction by this way.
See Nigels response in your other thread
