I have createt a table where i can insert data to but i also need button to move the select up or down, i have tried some code but cannot get it to work???
Hi Miol
You can add an attribute to a table parameter (provided it is backed by an INT16/INT32 and not an INT16_ARRAY/INT32_ARRAY) to provide a drag-to-reorder handle. If you would also like up/down buttons, you can use the example posted below to see how to shuffle the parameter values around:
function moveDown()
move(1);
function move(direction)
var selection = params.getValue(‘params.table’, 0);
var newSelection = selection + direction;
if (newSelection < 0 || newSelection > params.getElementCount(‘value_param’))
return; //If we are moving up but are already at the top or moving down and are already at the bottom
var newValues = ;
var oldValues = params.getAllValues(‘value_param’);
for (var i = 0; i < oldValues.length; i++)
if (direction > 0 && i != selection) //If we are down, add the value already at index first
newValues.push(oldValues[i]);
if (i == newSelection)
newValues.push(oldValues[selection]);
if (direction < 0 && i != selection) //If we are up, add the value already at index after
params.setAllValues(‘value_param’, newValues);
params.setValue(‘params.table’, 0, newSelection);
