Multiviewer Layout Save / Recall Carbonite Black
Hello Everyone,
I hope you can help me with our Multiview at the Carbonite Black.
I´m working at a German Football Club TV Channel and we are producing
in our Studio on Site, all Games from Amateur to Pro´s using
LTE, SNG, Local Cameras and so on.
Every Production use different Inputs, all patched via a Nevion DVKS.
Is there any possibility to create different Multiview Setups and save them for a later Recall?
At the Moment we need to setup a Multiview with different Layouts and Sources before every Production.
Thanks for your help!
Cheers
Hi Carsten,
There are a few ways to do this.
  1. Save multiple switcher sets, each one with its own multiviewer setup.
  2. Build Custom Controls that changes the multiviewer layouts and sources.
Method #2 (Custom Control) is a bit quicker in recalling a multiviewer layout than Method #1 (sets). But if you have other switcher setups that are different for every production (eg. memories, CCs), then saving a set will be neater.
Hey Aaron,
Thanks a lot that helped me really much. I directly tried the Custom Control Version and its working fine.
Never thought about that you also can record these Settings.
Thanks a lot again!
