Native codec
What is the native codec for Tria/Mira import? We’d like to export our videos in a way that will take the least time to import.
Hi there, Sorry it has taken a while to reply to you on this. There are several models of Tria and Mira and the native codec on these are different depending on which model you have. Would you happen to know what the exact model of you have is? If, as I suspect, you have a Mira (which also comes with Tria functionality), then you will probably have an AVC-I or DVC-Pro unit. In the case of the former, the native codec will be AVC-I 100 and the latter will be DVC-Pro 100 when operating in HD. In both of these cases, import and export of content in these native codecs will be blisteringly fast, much faster than real time. I hope that this helps.
#Tria
What would the native codec for 1080p/59.94 playback be? it doesnt seem like AVC Intra will support 1080p.
Our Tria servers were purchased last year if that helps determine their model.
#Tria
