Need help with animated 2/4 box.
I need to make 2/4 box’s in MLE 1. those box should have a background or CG. for example: in
box 1: cam1
box 2: cam2
box 3: cam3
box 4: cam4
Background: CG
i need those box’s individually squeeze or expand on full screen. need some guideline to make this. is it possible through custom key or onky with the keyers or there are both options?i want to do this with vision 2M.
You can make the “base” memory with you 2 box or 4 box.
Then you could make 4 other memories (2 for the 2 box) where you make each of the boxes full screen but leaving the others in the small position. with the full screen also make sure you set the key priority accordingly as well.
Then you can use the EFF Dissolve feature to be able make them move from the base memory to these other memory positions.
#Vision
Mr. Les
Thanks for your reply. If you could post a video about this it would be more clear and helpful.
Thank you again.
#Vision
I am traveling this week and will not be able to get to a video until I am back in the office next week.
#Vision
No problem. i can wait. thank you.
#Vision
Hi Mashroor,
Sorry for the delay but we had the Demo Room booked and then I needed find a camera. This video is kind of low end but I really wanted to get you something before I headed out on another trip.
https://www.dropbox.com/sh/5efa5dan3qs8taj/kFSI1SuR2V
#Vision
Hi Les,
Thank you so much. This is very helpful. I’m going to try this today. You seems travel a lot. Do you have any plan for trip in Bangladesh? If you then please let me know. I’ll like to meet you.
Best regards
Rokon
#Vision
