Obj Sequence
Kia ora
I export an OBJ sequence within Blender with the ‘export animation’ box checked.
I named the file 000000 so that the sequence/animation can load up - or be found - in Xpression.
I import the very first file - object shows up fine.
When I drag the OBJ ‘sequence’ from the materials manager to the scene director track. It only shows up with 1 frame.
Is there another box I need to check? Or is Xpression not reading the sequential numbers correctly?
I am trying to import an animated scene using an OBJ file sequence exported through Blender.
Any help, very much appreciated lol
HI,
Try Use C4d Obj Sequancer it will work.
