Opacity on a DVE key
Setting opacity with a DVE Key
Hello every one.
Is it possible to set opacity when keyer Is a DVE Key on a carbonite switcher
Thanks for your future answer
Kind regards
Guillaume Davy
Hi Guillaume,
If you apply a Self Key with the DVE Key, there is a ‘Transparency’ parameter on the Self Key page to adjust the DVE key’s opacity.
Hello Aaron
Thanks for your answer.
I’m sorry, i can’t select self key and DVE Key at the same time.
In France we say Cheese or Dessert !!
I want to make a pip full key with an opacity.
Is it possible ?
Hi Guillaume,
In Carbonite-land, we say cheese and dessert! Ok, we do not say that. But we like to implement functions that make sense.
Therefore, yes we can absolutely have a PIP with opacity. I have attached 2 screenshots to guide you.
Screenshot 1
  1. Assign as a Self Key.
  2. Select DVE.
  3. Turn on DVE.
Screenshot 2
  1. Go back to the Self Key parameters.
  2. Bring down Clip and Gain to get back the image.
  3. Adjust Transparency as required.
Hope this helps.
