Is it possible to output the end position of a crawl while it is animating in the framebuffer? I’d like to trigger a scene director script once the end of the crawl has reached a certain X position. Thank you.
Hi John.
In this case I recommend to use event marker which position x equals text position plus text weight in VL. And scrip below when event is OnShow
Dim frambuffer As xpOutputFrameBuffer
Dim scn As xpScene
Dim anim As xpSceneDirector
engine.GetOutputFrameBuffer(0, frambuffer)
frambuffer.GetSceneOnLayer(0, scn)
scn.GetSceneDirectorByName("anim", anim)
anim.PlayRange(0, anim.Duration)
Thank you, Roman, for the reply. In this case, however, I’m trying to dynamically track the end point of a crawl within a scene group that does not use a scene director. I was looking through the xpSceneGroup members in the SDK and didn’t see anything. It’s possible I may have missed something.
