Overdrive Direct Control Question
In Direct Control, you have a button that you can press on an audio source that will save teh current audio level as the new default. Where does that setting become stored for the long term? We have noticed that some times the new saved default will change when a new show is loaded.
Any Thoughts or Ideas?
You can change the settings to “Keep” and the slider will not be affected when someone changes the slider level.
#OverDrive
