Has anyone built a panel builder filer for the Panasonic PTZ cameras? I have the web interface working with the ip address, but would like something a little smoother.
Also, any sites that house downloadable panel files?
The Panasonic cameras respond to HTTP POST or GET commands. Each command requires sending a message to a URL.
People have controlled AW-HE 120 using ogscript.asyncPost commands in DashBoard.
Note: Some Panasonic cameras require HTTP POST and some require HTTP GET (the AW-HE 120 responds to POST).
To do a post from within DashBoard, the “data” argument in ogscript.asyncPost must not be null:
ogscript.asyncPost(“URL_GOES_HERE”, “”, CALLBACK_FUNCTION);
To do a get, set the “data” argument to null:
ogscript.asyncPost(“URL_GOES_HERE”, null, CALLBACK_FUNCTION);
You can find the Panasonic protocol at:
Ross Video also makes/sells a Custom Panel to control these Panasonic cameras. If you are interested in pricing, you can contact Greg Quirk at gquirk@rossvideo.com
Hi #jamespeltzer
I try to recall a preset but doesn’t work. When i go back to the code, my & is transforme in &. Is it the reason doesn’t work ?
That shouldn’t be the problem.
The change from “&” to “&” should only be in the XML view of the panel. This happens because “&” is reserved in XML (as are “”). When it is read from the XML document back to the script, the “&” will be transformed back to “&”.
Can you post the code from your Custom Panel so we can take a look?
