Question about Carbonite Ultra clock
Hello all,
I have a question related to the internal clock of the Carbonite Ultra. I can find two clocks in the menus: one under Status/Power menu, and the other in Configuration/System/Global. The first one is in sync with our reference input. The second one can be edited manually.
My issue is that the second one is used in switcher logs and each day is a second off. And if I forget to update it regularly, sometimes is off by several minutes. And obviously it doesn’t follow the daylight saving time, that adds another hour.
Is there a way to link it to the other clock, that is in sync?
Thank you!
The Clock you see running in the Status menu is probably tied to the LTC port and your facility sync and clock. The OS and Logs are not able to use that clock as they need to lock to the OS time and what the system clock is running off of.
We hope to have a release out later this year which will allow you to connect to an NTP for the system time.
TD Panels version 3.3.1 which is being released now has support for this.
That makes perfect sense. I will wait for the update.
Thank you, Les!
Any updates on the NTP clock? Would really like this.
Will be in version 12.20 – which is currently in PV.
If all goes well should be on the download pages in the first week of November
Hey Les! Do you have any idea if version 12.20 will be compatible with Overdrive/Caprica systems?
Thank you
Hi Les, thanks for the update on the NTP support. Just to confirm: is version 12.20 the next release for the Carbonite Ultra (currently 9.2.2 on the download page)? I only see DashBoard 10.0.0 (Nov 9) on downloads.rossvideo.com so far, so I wanted to check whether the release date has shifted. Also, does the NTP setting replace the manual clock under Configuration > System > Global, so that the switcher logs follow it? Thanks!
correct 12.20 has completed PV and we hope to get it up on the downloads this week. It just has to go through release process
