We replaced the original XPression hardware with another XPression hardware for the demo and continued the work.
However, in the original XPression, it was used in conjunction with the equipment of the audio mixer, and when setting up the audio, the mixer equipment was seen within the XPression.
However, I did the same setting after replacing it with demo XPression, but the mixer equipment does not come up within XPression.
XPression can only pick up audio devices that are properly installed and avaiable in Windows.
The audio device must also be installed and available BEFORE opening XPression.
Ex. a USB audio device must be connected and working in Windows before you open XPression, for XPression to detect it.
What is your audio device? How does it connect to Windows? Is it using a Motherboard/Sound card device/input? Or is it a USB audio device? Does it need Windows drivers installed to work?
