Replacement Power Supply
I need a replacement power supply for my Carbonite control surface. It is the older style with a standard power supply plug and not the white 6 pin plastic one.
Would any 12 volt 4 pin power supply work? Is there a pin polarity I need to be aware of or will any standard power supply with those specs work?
Cheers
Hi Brad, That is a 2 Pin power supply not 4 Pin.
The requirement is 4 amps on 12v so any supply that is 12v DC with 4 AMPs or greater ability (note that a supply rating is the max it can supply so a 6A supply is not going to cause an issue) Center Pin is Positive and Barrel is negative.
