Roller Text Jitter
I’m running a roller using the one text box method. It’s very long and runs through in a 30 sec window that matches some music.
The roller box runs and then the end board, on a separate layout, rolls in, stops and animates the logos.
It has been noted by engineers that the text flickers, getting better or worse depending on the speed.
Has anyone else noticed this and what solutions do you have?
Regards
Do you have an example?
Hi Red
I’m on an OB at the moment but when I can I’ll send you the job Hx
Sent from Mail for Windows
I can look at it and see if I see the flicker, if I don’t it may be something being introduced locally.
