Is there any way to control those lines point from visual logic , so i can datalink those line in dashboard number ..
thank you
thank you
Currently those data points can only be modified with scripts.
can someboady help about this scripting lines in xpression iam totally news to scripting which can be control with dashboard integer parameter
thank you
can naybody please help me to write this script please … just idea so i can talk with programmer
Sunil,
Here is a basic project that should help with this, I have 3 textobjects that represent X,Y,Z.
Each textobject has a “OnSetText” Script that runs when the text is changed, this script will set new position coordinates for the second point in the first point list.
Here is the project: https://transfer.rossvideo.com/f/d65068d41d08fc05
Can you post this again? I’m trying to do the same thing and can’t find a script to do it.
Here you go!
can you share the file one more time
