I’m trying to put in place a tcp communication using rosstalk and my device.
I’m using the sendmessage method with callback. The callback function is the one supposed to give me the response of my device a a tcp message.
The problem is that the response is always a null string.
I was wondering if there is a bug in Dashboard or if i’m doing something wrong.
The code looks like this:
function callback(success, sentData, resultString, exception)
ogscript.debug("TCP result: " + resultString);
var ip = params.getValue(0xC,0);
var port = params.getValue(0xD,0);
rosstalk.sendMessage(ip, port, message, callback);//Send message to external device
I would appreciate if somebody could shed some light on this issue.
Bruno
Hi Bruno.
Unfortunately, the rosstalk.sendMessage will typically terminate the message after it has been sent without waiting for a response. The only exception to this is if the message sent ends with a “?” character. This is because rosstalk.sendMessage was designed for “fire and forget” messaging.
If you need to engage in a multi-message conversation over TCP/IP, one option you have is to use a tag (which can act as a server or connect as a client).
Hope this helps.
Thanks James for the quick answer.
Bruno
You’re welcome - please note that the post should have said " tag" (the forum originally hid the tag because I hadn’t escaped the brackets).
If you have any issues using the listener, please post back and we’ll do what we can to get you sorted.
