Hello Everyone,
I want to trigger keys using a applescript. has anybody done this? and if so do you mind sharing your code.
wanting to setup the applescript to remote trigger the key over my network.
I have a crossover 12.
Brad
Hello Everyone,
Brad
CrossOver Does not support RossTalk. You can use the GVG 100 Protocol over ethernet using the gvginject LUA commands.
info can be found in this document
http://www.rossvideo.com/pdf/cutsheets/crossover-interface/GVG100-Commands(4802DR-401-03).pdf
