Is there a way to turn key 1 off when input 6 is on program, and turn it back on when input 6 goes off?
You could make a DashBoard application that would track this using Visual logic and turn it on and off.
Here is a link to something similar but to switch another bus. You could setup rules to just change the key state.
http://discussions.rossvideo.com/forum/default-forum-gc1/carbonite-production-switchers-gc18/9979-substitution-tables
You could make custom controls…
Take Input 6 and turn key 1 OFF
Take Inputs other than 6 and turn key 1 ON
I would build each custom control above the input it is controlling
---- another way would be;
Make a custom to take input 6 and turn key 1 off, then add the dialogue to select key 1 and background… you then have to preset the next source to take on preset and press cut manually.
I know we can use custom control, the problem is the time input 6 will be on air, 5-8 seconds. I will try to use Visual logic, but I have never used it before.
