Is it possible to send CII commands from Xpression to another system?
We are using version 10.5.
Thanks for any help.
Hi John.
No, there is’t any CII events in the Xpression.
But you can use a Rosstalk event for send commands to another Xpression system
You can’t send CII commands from XPression, but the XPression CII Gateway can forwards commands from one to another. You can then use CII machine IDs to identify which CII commands are triggered on which machine.
Although it depends what workflow/goal you have here.
Roma’s suggesting is certainly the best way to trigger one XPression system with another (and with frame accuracy)
Thanks for the suggestions. We ended up using Diagnostics.Process.Start(“path to application”) in OnOnline to run an app to send commands.
