Set a keyer to disable/hide when a particular source is selected?
Hello! I have a question based around some automation. If I have a camera shot on source/input 4 that’s wide, I don’t want our lyrics overlay (key 4) to be visible when I cut/transition to that wide shot. That wide shot has our center screen with lyrics on it aready and its redundant. Not to mention I am limited to what that wide camera can be tilted because I have to compensate for the lyrics overlay key.
Can I have key4 automatically disable or hide when input 4 is live on the switcher?
Thank you!
You can latch key 4 and background in the transition area before cutting to the wide camera. So in in the transition area hold BKG the press KEY 4 before pressing CUT or AUTO TRANS.
Get Outlook for iOS
Awesome. That works Thank you. I had some time to practice the flow of doing that last night. Just have to get used to latching in quick, in-the-moment situations.
You can also save a memory with the wide camera in program and the Keyer off. This will allow you to cut to the camera on air with the keyer turned off. This memory can be recalled manually or with a Custom Control.
Get Outlook for iOS
