Set Font Size on line index
i am going to set font size on line index. When there is a second line, it will change font size to script below. placing the script on setline. compiling successfully but no result on end side.
dim font1 as xpFont
LineIndex = 2
font1.Size = 65
Rest it will be keep default with line 1 = 100
Personally, I would have a second hidden text box with smaller text and just toggle visibility.
It’s not as smart as what you are doing, but it will work and it’s much simpler and reliable and will work with visual logic.
Is it possible for you to share something from your magic box?
have done in this way. by VL
Personally I would have used bounding box height, when its double a single line you’ll know its gone to 2 lines.
More reliable than length.
Yes, it is. However, I was looking for some additional ways to reduce size rather than squeeze or wrap.
No I mean, bounding box size for getting the line break, not squeeze or wrapping.
So where you use length you should use boundingbox.height I mean rather than length.
Yes, that was more feasible with bounding control. Cheers!
Hope to see in your “How To” series in your YT Channel :grin:
yes, its already been there. with updated one … :grin: :grin:
