Setting Default Bus Map
I’m blanking on how to do this. I can see that I have a preset bus map saved into the DFAULT BUSMAP (MENU > RESET > NEXT > NEXT), but I can’t figure out where I originally set it? I saved a complete set from which was able to restore my settings, but I can’t for the life of me see where the ‘Default Busmap’ is coming from.
Rob.
Originally posted by ****
The default bus map is the default from Ross, there is nowhere to set your own default bus map. The best way have multiple bus maps is through saving switcher sets and recalling them.
Man, it’s obviously been a long time since I’ve looked at my input list if I didn’t recognize a straight bus patch…
thanks for the clear and quick answer, as usual.
R.
