Hello all,
We are using a Vision switcher with Overdrive. We’d like to adjust the default level QuickAudio sets our Digicart fader to, but I’m not having a ton of success. The default level when using QuickAudio seems to be 40%. If there’s no quick audio on the line within ENPS, it sets the fader to 75%; which is where the fader default is set within the Vision. The Digicart fader within Template Editor is also set to “default” across the board. Is there a place that I’m not looking that might be setting the default to something other than 75% or “default”? Any help would be appreciated!
