Shift Key won't turn off
Originally posted by ****
Hi all
I had to use a shift key on my switcher today. Now the shift key won’t come off. Can anyone give me a hand with this?
if you just press the first button what do you get?
When selecting a shifted side source you hold the shift down. After that you just select a non shifted source and don’t hold it.
Also possible to have pressed the Shift twice quickly and are in Shift Hold Mode.
Thank you! Literally a few minutes after I posted this I figured it out! I did not know about the double tap… good to know
