Swap rack mount chassis
Hi
We have a Carbonite 1-A-16 with a chassis which has 6FCFS
We have just purchased a 1-M-16 with a + chassis with16 FCFS
If needs be for a job that needed more fcfs could the + chassis be used with the 1-A-16 or the 1-M-16
They are both desk mounted and that would save uninstalling them our vans for that job
Hi Peter,
Carbonite frames will work with any Carbonite panel, so yes you can use either panel on either frame. Just be aware that you will of course need to create different button maps for each panel, but that is simple enough.
Nigel
