I am trying to set up an on-screen bug for sports broadcasts fed from the scoreboard. The scoreboard is a Daktronics All Sport 5000 and it is feeding into Graphics Outfitters equipment (ScoreIP to Score Bridge running on the Xpression). In Score Bridge I can see the tenths of a second tick off correctly, but when it gets to Xpression, I only get about two updates per second. I am using Graphics Outfitters recommended JSON feed into DataLinq as an RSS/HTTP source. The settings point to a URL provided by Score Bridge which is the local Xpression computer. I have tried different update intervals, but I get the same results. I have tried several other ways to feed the data to DataLinq and if it worked, it was no better than the json file. I am at a loss on this one.
Do you have a way to look at the data as it hits the PC within windows other than Datalinq to compared?
