Tessera video reading speed issue
I have the following issue while using Tessera in Single Engine Mode.
Tessera v10.5 build 5510
Project 1080i 25
Video ProRes 422 25i encoded in 25i
4 channels 1 excluded from Tessera and 3 using Tessera
Everything is working perfect except for the duration of the videos in the Sequencer. I have 4 videos with the same 40 sec length. One is played on an excluded from Tessera Channel and the rest using Tessera. The one excluded from Tessera has the right duration 40s while the rest have a 80s duration.
In the sequencer the duration of all videos is 40s.
I’ve noticed one thing.
If I play the videos from the Clip Store I have the issue.
If I play the videos from a Scene Director with the video on the Time-line I have the issue.
If I play the videos without Scene Director and set to auto start in the material run mode it works perfect.
Regards
Karim.
Just to let you know that I recieved the following message from TechSupport.
Regards
Hey Karim,
I have reproduced this on my end and I’m going to escalate it to our team to get a fix implemented.
