Text Sizing Issues
Hey I’m having issues with my text resizing to a smaller font once I push a button (I’ll add pictures to hopefully make since of that sentence). Has anyone had this problem or does anyone know what the fix could be? This only happens on any of the buttons in the 4X8 table. The row of buttons at the bottom, separate from the 4x8, do not resize once pushed. I have gone to the style page in editor mode and made sure that they were set to the same size for “default”, “Toggle on”, and “Toggle Off”. These are all “push” buttons.
Any help would be greatly appreciated!
Is this from components dragged from a Carbonite?
If so, the only solution would be to override the constraint associated with the button to remove the style information being sent from the device.
If you do this, the button will still toggle off/on but the name, up-colour, down-colour, and other style information will be specified by you in your custom panel:
If you remove the highlighted text (from both constraint values), you will be able to specify the style arguments yourself.
James, You are a wizard. Thank you so much!
