Trigger Next Graphic, Looping Group
Hey Everyone,
Trying to find a way to send a trigger from a switcher (via Ross Talk) to Take Next (or maybe a different command) in an Xpression group, and to continue to loop that group.
Basically doing sports with a sponsored replay. There are only 4 sponsors and they live in a group on the Xpression. I would like for the sponsor to change every time a replay wipe is run, and to start at the top of the group when it gets to the bottom. Basically creating an endless loop that recalls the next graphic each time all game long.
Any thoughts? Thanks!
on the group option you can put group into timed but then in the options you set manual advance and then you just keep taking the same item number but it will advanced once each time you take it.
