Triggering a transition
Hi All.
Im just beginning to tinker around with Custom Control panels inside Dashboard. I have my Xpression linked up using Ross Talk. So i’ve been able to create simple take, clear, etc. commands. My question is, is there a way to create a custom control that would call up a Xpression file(for this instance an animated file) while ALSO triggering a transition on my Carbonite switcher? I’m new to the game so i apologize if this topic has been covered already. Any help would be appreciated.
Absolutley!
When you set up your tasks, in visual logic, there’s this little green pluss sign next to Devices and Parameters.
If you click that, and then “Add Carbonite”, insert the correct IP and Port, and you’ll get this little folder there for your Carbonite containing all the RossTalk commands you can easilly send to your Carbonite. Basically making you set up a bunch of commands to the Carbonite simply by one button :slight_smile:
Have fun!
You can also do this within the Custom Control Shotbox editor on Dashboard.
Thanks guys! I’ll try this out
