Triggering NK Router Mnemonics to Carbonite Ultra Crosspoints
HI,
is it possible to trigger my NK Router 144X144 mnemonics to the carbonite Switcher. i had added some of the Router destinations as inputs to the carbonite Ultra switcher .and so i expect whatever sources from router are input to the Ultra the same Mnemonics need to be reflected on the Ultra crosspoints display . i had read that we can use rosstalk in dashboard using port 7788 to create this functionality . could i get some help or guide regarding this
There is no documented way to do this in DashBoard or guide.
It is possible to send Mnemonic name changes to Ultra via RossTalk - Note unlike TSL UMD protocol this will update the source Label in the Input Table as well as the panel mnemonics.
lists the commands with the MNEM command being the one you would send from DashBoard. You would need to build a DashBoard Custom panel of some kind that is going to be tied into your Labels and I speculate some kind of Router I/O Panel that would need to be running that will you will add code to send updates to the switcher based on changes to specific outputs.
