Two buttons are lite up (cam 1&2) and I can't reset them
Originally posted by ****
Cam 1&2 buttons are both on. I can’t reset them. Tried resetting switcher - they are still on. Rebooted system - still on. On/off - still on. Does anyone know how to reset them so I can switch between cam 1 and 2?
You probably edited the Bus Map and assigned the same source to both…
Patrick: It may be that the same source is assigned to two buttons in the Button Map. Check Config/Button Map and be sure that Cam 1 is assigned to one button and Cam 2 is assigned to the other one.
Beauty! That was it! Thanks a bunch!
