Hi again.
We are planning to update Ultra to a newly-released software, it is quite interesting for me will it be able to pass an embedded audio through output even if FSFC applied to the inputs respectively?
Hi again.
Hi Shamil,
With a change to the HD SRC mode you can have Sample Rate Converters for every FSFC that you enable. To make this possible the output converters have been reduced to only be on outputs 5 and 6.
