I can’t seem to find any way to disable the web interface or SSH access on our router control panels. Is it possible? The SSH default credentials are root/root which recently led to malware infecting one of our Ultrix routers. I’d like to be able to prevent that in the rest of our Ross hardware, but it’s proving tricky.
Anyone have any tips to improve network security on these RCPs?
The hardmode solution I’m trying is to rename/move the file /etc/init.d/S60httpd so that the web server won’t load on startup, and to change the password of the root account, but it sure would be nice to be able to toggle these services via Dashboard.
Hi Kyler
Upgrading to version 1.75 on your RCP will give you the option of enableing and dissabling SSH from Dashboard.
Send an email to support@rossvideo.com and we will set you up with the software.
!(https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/UploadedImages/LGSYqeSRbungRIchMj7w_Screenshot 2024-06-13 at 12.59.58 PM.png)
Support responded quickly and got me the firmware I needed. Thanks!
Fantastic Glad to help out.
