Is it possible to send commands to increase and lower the brightness of the Ultritouch panel? I know you can go into the menu and manually do it but I was hoping for the option to just send a command to do it. Thanks.
The ultritouch has a parameter called deviceoptions.lcdbrightness. You should be able to set/get that parameter to control the brightness from another panel.
