Is there anyway to put a “last” button on the ultritouch HR? I’m looking for a quick one press way to go back and forth between two sources.
Thx
Thx
Hi Omar,
For softpanel, you can reorder the panel’s assigned sources where the two desired sources are placed at the top of the list. Which softpanel style were you using in Ultritouch HR?
Hi Omar
I posed this question to our internal team responsible for the Ultrix soft panels that run on Ultritouch (which I presume is what you are referencing) and here is their reply:
“In panel editor page where you create softpanel, you can reorder panel’s assigned sources by selecting desired sources and clicking on the Top button to place these sources at the top of the list. The softpanel layout will refresh and show desired sources, first (so you don’t have to scroll up/down looking for it)”
Not quite a “last” button but at least you can have your frequently-used sources in a more convenient position.
Hope this helps!
