ultrix 5ru setup
I have one ultrix-5ru with 3x SDPE. How can I config/router the carbonite AUX bus to ultrix router physical output? Thanks.
Hello Howard,
Just want to make sure - is your carbonite a standalone frame or is it configured within one of the SDPE blades? If standalone, what model of carbonite?
Just want to confirm: Is this a standalone carbonite frame or is one of the SDPE blades configured to be the carbonite? If it is the latter: go to Navigation Menu, configuration, Outputs. These are routable, you can change these to be any of the AUX buses. Once you identify the position, you should be able to find and trace it within the database. Your Carbonite Outputs are likely already in your Ultrix database. I believe all you would need to do is create a route to an available Ultrix output using a router panel within Dashboard. If you do not have this already set up, I highly recommend giving Ross Video Tech Support a call.
