Ultrix 6.3.0 UI Issues / Feature Requests
After updating to 6.3 there are several UI improvements included, but some have reduced or eliminated functionality that was present in prior releases. I’m posting this here so others can compare and see if they have the same problems. Honestly, the improvements have been nice and the addition of Ultrimix-Dante has been a big improvement to our workflow.
  1. On the salvo edit screen “Capture Destination Status” only allows to save selected destination status to a new salvo instead of being able to update the currently selected salvo. We use this when saving minor changes to an often used salvo, rather than having to select ALL of the needed destinations such as updates to monitor wall PIPs.
  2. The Salvo creation page has arrows for scrolling sources/destinations up/down and left/right, but not scroll bars. The scroll bars are still present in Matrix style soft panels, and honestly the scroll bars are better since the minimum you can move with the new buttons is an entire page at a time which makes it difficult if needing sources/destinations that span across a “page”. Imagine only having “Page Down” on your keyboard instead of line by line scrolling on a website or word doc.
  3. Loss of “Favorites” tab on TouchDrive soft panels. Has been eliminated in the user guide as well. Favorites is still a button option, but cannot edit the content of that tab.
  4. Sources/Destinations page does not allow “rename” function in the Description column. This can be worked around with an excel export/import.
  5. Sources/Destinations page struggles with Channel Aliases. I cannot manually type or select from the dropdown a video/audio channel that has an alias. Some cells refuse to display channel aliases as well. We have for instance relabeled audio channels as “Dante In 1” or Video channels as “SDI IN 12”. Using the “Edit” dialog on the left side does show the appropriate channel aliases. Typing in manually results in the error “Problem getting channelId”
  6. Sources/Destinations Page “Edit” Sidebar could use a filter for audio/video channels and multi-select for slots.
  7. When using Alias Sets for Ultriscape UMDs, Changes to the Aliases do not push to the monitor wall unless I change the Alias Set in Ultriscape Head selection and change it back.
  8. This could be expected functionality, but we operate the database in “Manual Save” mode and every time when editing a cell in Sources/Destinations panel there is a few second delay with a spinning circle before we can enter and edit another cell. This makes editing multiple names/descriptions/tallies a chore.
  9. This is more of a feature request, but its based on a new UI function: On the salvos page there is a “View” button that toggles from Matrix view to a List view of all the salvo commands as selected, including showing all levels included. Please create a soft panel view that looks like this, but with live crosspoints. The “Pie Slices” is not helpful in some cases and multibus has some of the functionality, but isn’t quite right for what we need. I would like to be able to see a destination and the status of all 17 levels, even if it’s read only. Ideally it would just look like the destinations table, but with crosspoint status in place of the physical port definitions.
  10. One more feature request is Mouse Wheel support for “Matrix” Style soft panels and Salvo Configuration pages.
Hi Jason,
Thank you for taking the time to document all of these suggestions. I have passed them on to R+D and we have entered them into our product develeopement roadmap. Hopefully we will see some (or all) of you suggestions in the upcoming releases.
