We are running an Ultrix Carbonite FR2. I am trying to get my Carbonite mnemonics to follow my Ultrix source names with no luck. I have selected The TSL ID and type in the input configuration of the Carbonite and also gave the corresponding Ultrix sources their respective Tally IDs. Tally is active in the database and I created an outgoing TSL/ UMD 3.1 connection on my Ultrix. But unfortunately, my Carbonite mnemonics read TSL 1 and so on. My Ultrix multiviewers are receiving tally data from Carbonite. What am I missing here? Do I need to create a device in Carbonite to receive the data?
You need to setup a device in Dashboard for the Ultrix to send to the Carbonite as well.. The Carbonite is always running the TSL Input server as 5257 tcp..
Thanks! It works now. I had setup the outgoing connection correctly (I thought), but when I reconfigured it I used the Device ID that you input (UxC) and it worked. Is that Device ID (UxC) required to make it function correctly?
Thanks again!
Not a specific one .. but does seem like something needs to go in there .. since I have a graphite / Ultra and ultrix Carbonite all talking to the ultrix I just chose those names for me…
Hello, I’m setting up an Ultrix Carbonite. Multiviewer’s UMD is working fine, but I could use some help:
is it possibile to assign to one PIP more than one UMD, each with a separate address? So far, every PIP get the same label as the PIP;
what is the correct configuration to read the Carbonite tally status? I have tried to add a serial tally slot (Carbonite) and also an outgoing connection on the Ultrix, ma Tallyman says connection is down (but I can read Ultrix status as a router).
Do you have specific instruction for this? I have tried with the legacy Carbonite guide I found here but this one seems different.
Hi Silvio – are you referring to the “internal” carbonite MV or the Ultrix MVs?
could you post some screen shots of the item configuration you have and then maybe a picture with an explanation of what you would like to be seeing instead in the MV display?
Hello! Actually both. I will post a few screenshots next week (I can’t access dashboard remotely), but the basic idea is two have a PIP with two UMDs (a city and an event name) both coming, if possibile, from Tallyman. So far, one of them is static – acceptable solution if not ideal.
Do you have any suggestion about the second point?
Cheers.
The Switcher MV UMD can be setup to accept TSL and also show the Switcher User Name.. Say Input 1 is CAM 5 in the Carbonite Input Name and the TSL Name Coming in is LONDON then in the Carbonite MV Settings you can enable Per Box the Label “Display” Option to have Both / Mnemonic / TSL and with Both you would see “CAM 5:LONDON”.
In this example my Input 1 is named CAM 1 and the TSL coming from my Ultrix to the Ultrix Carbonite is GRH 05 …
So my Label would be “CAM 1:GRH 05”
Hi, thank you, still not optimal but I could use it (I have an existing integration feeding city names from a database to Tallyman).
Any idea on how to read tally status from tallyman? All I can see on the Carbonite is the TSL Serial Tally driver installed: apparently it is what’s receiveng names (port 5727) but no way to read tally status from it.
Cheers.
In the Input configuration you setup you TSL UMD ID to track and then you setup if you are to get TALLY for that source from the switcher Tally Management or from the external TSL controller management.
HI,
I apologize if I didn’t make my clear. Your last picture is about receiveng tallies on the Carbonite. I have already configured it, and it works. What I’m trying to do is * to send* tallies to the TSL. I would normaly set up an IP slot or a serial port for that, with serial tally protocol, but I can’t seem to find it here.
The only thing I can find is the serial tally driver in the “Device” tab, but it seems to be on the receiving side (the one above).
While we are at it, is there some optional driver list? I could also use a Sony BVS Editor control.
Thanks again.
http://help.rossvideo.com/carbonite-device-db/index.html
List of devices and configuration. Yes you have to setup a Port in the Carbonite to Send TSL to the Tallyman. In the Tallyman you setup to run as a Server and the Carbonite is running as a client.
http://help.rossvideo.com/carbonite-device-db/Topics/Devices/UMD/TSL.html#topic.tsl
Link for the TSL out configuration and then the “ID list” that TSL will use for the Tally status.
Hello!
Thank you very much, it’s working now!
