Ultrix Carbonite
Just wondering if anyone is using an Ultrix Carbonite in an overdrive situation?
Can you turn a mini me into a program bus and if so how many keyers would it have?
Kenny
You should be able to and you will only have 2 keys, dissolves, and cuts.
Louis Santiago
Product Prime-Switchers
Ross Video | Let’s make it real
T: +1 (613) 652-4886 M: +1 (719) 367-2240
Louis.Santiago@rossvideo.com
Ultra60
Sent from my iPhone, please excuse any typos.
You can – you would have 2 Keyers and the only transitions (outside of using a keyer for an animated transition) is going to be Cut and dissolve.
There is a 3ME mode in Ultrix Carbonite where you give up the MiniMEs and have the 3ME 6 Keyers… and you still have the UltraScene .. so you can have a single “ME like” crosspoint that has a background and 8 Keyer Layers … or you can split them up in pairs to a max of 4 scenes with 2 Layers and a background each..
Thanks for the info Les.
Much appreciated.
