Hi People,
I’ve recently discussed with customers how the control for the Ultrix can work. Currently, the controls are only available via Dashboard, either on PC or UltriTouch, as well as the NK-Panels.
Is it possible to have web-based access, to the Ultrix through a different port to be able to access the panels of the Ultrix? This way the routing could be controlled even by a Tablet in the network, which would be a very flexible solution.
Do you think this would be a feature also interesting to others?
Regards,
Dominic
