I’m working on a Dashboard that communicates to a variable number of record decks via AMP. I’m trying to make the script modular enough that I can select the amount of decks and have it populate the Dashboard with the appropriate number of buttons for each deck. I’m able to populate the Dashboard based on the number of decks selected but I’m having an issue with each listener updating with their respective IPs (Based off a text box that each is associated with).
I looked at the Hyperdeck example and it looks like the listener host and port is referencing the value of the text boxes on the sheet but any time I try to use the %value[var][0]% string the code seems to break. Is there a trick I’m missing or a better way to do this?
Are you using an ogScript variable or a parameter OID for your ‘var’?
Also, if it is a String-based OID, you’ll need to put single quotes around it.
I have just verified this with:
%value[‘Server_Host_Name’][0]% as the connection info does work.
if (event.isConnectEvent())
this.writeString("Connected!\n", false);
else if (event.isMessageEvent())
ogscript.debug("GOT : " + event.getBytesAsString());
this.writeString((event.getBytesAsString() + "").split("").reverse().join("") + "\n", false);
//We are connected!
ogscript.putObject('connection', this);
ogscript.rename("incoming", event.getBytesAsString());
else if (event.isDisconnectEvent())
//We are disconnected
if (ogscript.getObject('connection') == this)
ogscript.putObject('connection', null);
var connection = ogscript.getObject("connection");
if (connection != null)
connection.writeString(params.getValue("Outgoing_Text", 0) + "\n", false);
Hey James,
Thanks for the response. Hmmm… the problem may be deeper than that then. It looks like my code is correct but for some reason the value won’t update.
var i = 0;
var tot = params.getValue(‘numListeners’, 0);
var x = 16;
var str = ‘’;
var posY = 0;
while (i < tot) {
var listenerIP = ‘listener’ + i;
var newIP = {
“oid” : listenerIP,
“name”: listenerIP,
“readonly”: false,
“type”: “STRING”,
“widget”: “TEXT ENTRY”,
“value”: “DECK #” + i + " IP ADDR"
var newParam = params.createParam(newIP);
var listenerIPConnection = listenerIP + ‘Conn’;
posY = 20 + 80*i;
str = str + '
ogscript.debug(\'new IP: \' + this.getValue());\
ogscript.debug("TASKINGTASKASK");\
if (event.isConnectEvent()){ \
ogscript.debug("CONNECTING TO THINGY");\
ogscript.putObject("' + listenerIPConnection + '", this); \
ogscript.debug("CONNECTING TO:' + listenerIPConnection + '");\
sendNextMessage("' + listenerIPConnection + '", ["CRAT0007204Vtr1\\n"]); \
else if (event.isMessageEvent()) \
ogscript.debug("[RECEIVED] " + event.getBytesAsString()); \
else if (event.isDisconnectEvent()) \
ogscript.debug("-- CONNECTION CLOSED! --"); \
else \
ogscript.putObject("' + listenerIPConnection + '", null); \
ogscript.debug("Button2");sendNextMessage("' + listenerIPConnection + '", ["CMDS00042002\\n"]); \
ogscript.debug("Button3");sendNextMessage("' + listenerIPConnection + '", ["CMDS00042000\\n"]); \
i++;
ogscript.setXml(‘dynamicContent’, str);
When I set connecthost to a static value everything works minus changing of the IP with the parameter text box, but when I try using the %value method it doesn’t seem to do anything or trigger any of the tasks tied to the listener. Maybe there’s a character escaping that shouldn’t? It’s pretty rough to debug the code since I’m setting the XML through the button task when I try to edit and look and what code it’s creating it goes away.
Hmmm… Here’s an interesting discovery… I stepped through the debugger and pulled the ‘str’ variable out and pasted it into a new dashboard panel. I added in my function and the parameters manually and it still didn’t work. BUT, when I went to the task and separated out the code with line breaks to ‘clean it up’ when I saved and applied it worked. I may be even more confused now.
If you’re dynamically-generating your XML via ogScript, then there is no need to use %value…% at all:
connecthost=“’ + params.getValue(listenerIP, 0) + '” connectport=“3811” delimitertype=“newline” fill=“both” weightx=“1.0”
Note: If you change the value of your IP parameter, it won’t automatically-update the listener using either method until the code surrounding the listener is reloaded. If you want to update your listener at runtime, you’d use
ogscript.getListenerById(‘ID_OF_LISTENER’).connectTo(‘NEW_HOST_NAME’, PORT);
Ah, thanks James! I think the .connectTo() method is more of what I’m looking for. Is there possibly another method just to update the host and port? It looks like the .connectTo() method immediately starts the connection on top of updating the host and port.
There is not presently a way to do this, no.
Your best bet would be to not use the listener’s toggle button and, instead, create your own. This way you can wait and call ‘connectTo’ only when you are toggled on.
function updateConnection(listenerNumber)
var ip = params.getValue('IP_Address' + listenerNumber, 0);
var port = params.getValue('Port' + listenerNumber, 0);
var state = params.getValue('Connection_State' + listenerNumber, 0);
var listener = ogscript.getListenerById('Connection' + listenerNumber);
if (state == 1)
if (listener.getHost() != ip || listener.getPort() != port)
listener.connectTo(ip, port);
else if (!listener.isStarted())
listener.start();
else if (listener.isStarted())
listener.stop();
Connect
Connect
//DO STUFF
updateConnection("1");
Mulaky, what I did was make a push button that needs to be pushed after a IP and/or Port has been updated. Using the method James said on post2, you can just put in a ogscript task on the “load” button and re-load the listener, providing you have assigned it an ID.
// SET MITTI VTR A Primary Listen Port
ogscript.reload('1mitti');
