Upgrading Old Panel OS Cards
I have several compact flash cards with older versions of Vision Panel OS that don’t allow my current version of the Vision Panel application. I also have a newer card that was working that has a corrupt file system that can’t be self-repaired. When it comes to any other flash card or hard drive, a reformat and new OS install could fix that problem (provided there’s nothing physically wrong with the CF card).
Is there a way to clone an existing card to the older ones, or just use a card reader on a mac/pc and upgrade the cards that way?
You can run the USB Rescue where you boot from a USB drive on the Panel and then Upgrade the Compact Flash.
Here is a link to the most recent version 41 of the OS
https://www.dropbox.com/s/4nsnevsk0z461db/heracles-rescue-20140602-41.zip?dl=0
#Vision
Awesome! Thanks so much.
#Vision
ok, so I installed the first one and it loaded the Acuity software. The screen is stretched off the edge, so I can’t get to the buttons to change my IP address. I’ve plugged in a different screen that has a higher resolution like the new Acuity screens, but the buttons are still off the edge of the screen. I’m sure once I can connect to my frame and install the right Vision software version everything will be fine. Is there another way to change the IP settings? or perhaps another version of Panel OS 41 with Vision software on it?
#Vision
Did you have the DVI connected and the USB plugged into the Vision Touchscreen?
#Vision
If your still having issues here is OS 38 it will be fine
https://www.dropbox.com/s/j90no5q7ut1sve7/heracles-rescue-20130130-38.zip?dl=0
#Vision
perfect. thanks so much.
#Vision
