Does anyone know of a way to use Dashboard (or some other program) to display Clock and Score data for visual reference on our monitor wall?
We already have the data available on our network via UDP, which is how it feeds Datalinq on all of our Xpression computers. I am just wondering if there is a way to also display this data in a format on our monitor wall as well, using Dashboard and a scan converter. I wasn’t sure if there was some feature within Dashboard to display it, since Datalinq is already reading the data that is available.
Yes there is way. For this you have to use widget with label text in dash board through which you can send and expose clock parameter to datalinq.
You also have to setup streaming port of panel.
there is xpression u dashboard tut available.
for sample attaching file.
Hey Wajahat Ali,
I appreciate the reply. Unfortunately I want to go the other direction. The data already lives in Datalinq (it is already on the network via a UDP port), and I just want to display it using Dashboard, if possible. It is data that is already being generated from a scoreboard.
Any thoughts?
HI Kurt,
in my thought’s might I am wrong and let me correct more. the thing you want is to get datalinq clock in panel grid. might that can be
achieved by dashboard services through which you can get parameters of devices.
hope any one else have handy hands on this.
