The subject may be too broad, but here is my problem I’m hoping to solve for:
We are doing baseball graphics, and we can pull data from DakStats to get current batter info, and most information related to that batter(jersey number, last name, batting average, etc…), but DakStats is not passing us the First Name of the batter
Currenty, I have a seperate excel sheet that has a collection of all players Jersey Numbers, First Names and Last Names. I have a global DataLinq Key that is named Jersey, and I can quickly update that global variable to the players number, and it will pull the name from the excel sheet and all the other data from DakStats(position, batting avg, HR, RBI, etc)
Is there a way to make the Jersey DataLinq Key pull from DakStats as well, so I don’t need to update the slide every time…(I actually just make 9 of them pregame, and preset all 9 with the batting lineup, but then have to scramble to update if there’s a pinch hitter, or the lineup changed last minute, etc) I’m thinking a much cleaner solution would be if I can pull that Jersey Number from the live stats from DakStats and then use that to update the name from the Excel sheet, but I’m not sure how to make them both perform together.
I tried creating a new TextObject called BatterJersey and having that pull the Jersey from DakStats, which does output 15(current batter in DakStats), but when I tell the Name field to look in the excel sheet in row %BatterJersey% it doesn’t output anything(See Picture 4)
I tried responding from the email notification that you responded, but not sure it went to the correct place, Basically, I did not set this up originally, but am seeing that it is named Master Database Summary, so I’m guessing it is that(see picture for confirmation)..
Also, I do not have any experience writing a query to pull data(I’ve only used the Datalinq Properties tabs to pull data) or even know where to do so, but I’d be willing to try anything if you can point me in the right direction.
In order to get the data you want based on a datalinqkey you’ll need to use a query.
SELECT [column you want] FROM [table you want] WHERE (column you want to search by] = value you want to use to search eg “11G”
The example below shows I am looking for first name from home player table where the datalinqkey called “Jersey” is whatever value you have entered and you’ll see the letter G for game next to it, if I wanted season it would be an S there.
OK, that was actually really helpful, but not for the problem I was trying to solve for…I see what you are doingand that would eliminate my excel document, which I like and I have that working, but what I am wanting to do is eliminate the need to update the jersey number manually at all as well. When the DakStats updates for the current batter, the variable noB_NUMBER is passing the current batter, and what I would like to do is use that number to return the batter information instead of my manually entered Jersey Number, so I would like to not use a DataLinq Key at all, but I’m not sure how to combine the game in progress information with the Master Roster Information…essentially two lookups into the same lookup…Does that make sense?
I tried creating a Text Field that is pulling noB_NUMBER, and it does output the correct number, but I’m not sure how to use that text field as part of the query?
Yah, I tried that as well, and it was not working…but I do have a solution for anyone else following. If I replace Simon’s query from above with the text below:
SELECT [fstFIRSTNAME] FROM [HPlayerGmSn] WHERE [fstNUMBER] = (SELECT [noB_NUMBER] FROM [GameInProgress])
It works. That is pulling the number from the Game in Progress table, and using it in the Roster table to return the correct name.
