Using Video files into Xpression
We are using a project in wich we load videos as graphics. We need to use video encoder to transcode the media and to make it work in Xpression. Is there a way to get the codec directly into the NLE software ? So we would be able to directly export medias with alpha in the right codec and the play list creation would be less boring.
Best regards,
If the NLE software is on PC you can install our codec.
Great ! and where can I find the codec installer? on my Xpression frame itself or is it downladable?
Best regards,
Boris,
To assure you get the right version of the XPression codec, to match the version of XPression installed at your facility you should reach out to Ross Video Technical support. They can provide you with the proper versions and assist you with the install if needed.
calls +1 (613) 349 0006 | N. America: +1 (844) 652-0645 | Int’l: +800 1005 0100 | or email to techsupport@rossvideo.com
