HI,
I’m wondering if someone can help with the automated rundown creation.
In the Auto Create Options, how can i specify a folder that is within several other folders? I’ve tried entering it as Folder1/Folder2/Folder3/Folder Name but i keep getting an error that the auto create folder is not found.
Also, from what i understand there are way to have a date automatically appear in the name of a new rundown based on the air date. How is that setup?
Thank!
Hi Favian,
To sort automatically created rundowns to a specific folder, use a forward slash to indicate the path. Please ensure the folder names match exactly. For example, a directory named: “06 - Demo” cannot be typed as “06-Demo”, this will prompt the error you mentioned.
For dates, you can use the following keys: %M (month), %D (date), %Y (year). These are similar to the keys used to configure MOS Placeholder Templates. Here’s a link to that page on the Inception help guide: http://help.rossvideo.com/inception/help/v12.0/UserHelp/index.html#t=Online_Help_System%2FDialogs%2FCreate_MOS_Placeholder%2FCreate_MOS_Placeholder.htm%23XREF_28726_Create_MOS
If you’re still running into issues, a screen grab of the running order template settings, like above, would help.
Cheers,
Nikki Renoit
#Inception
Thank you Nikki, this was very helpful.
When using %M:R3 for the month, is there any way to specify upper case characters?
#Inception
Hi Favian,
There isn’t a way to change the casing of the abbreviations currently.
#Inception
