A new Beta Version of DashBoard Version 6.0 has been made available.
It can be downloaded at: http://www.rossvideo.com/terminal-equipment/opengear/control-monitoring/dashboard-beta.html
This version includes the following updates:
Updated Icon for Custom Panels - CustomPanels now have their own icon that appears in menus and in the File Navigator.
IP Addresses in Tasks can now be references - When setting an IP address in a task (such as sending a RossTalk command to a Carbonite Switcher) we now allow for defining that IP address by name. This is a HUGE time saver when you want to have your custom panel be remapped to talk to a different physical device (such as a Carbonite switcher or XPression character Generator).
Linking of .grid files in WindowsOS to DashBoard - Selecting a .grid file in Microsoft Windows will now launch DashBoard and open that .grid file.
Tables "“ Addition of UI to choose location of tabs - Tables now have a UI in the editor to allow choosing the location of the tabs themselves, each of the 4 edges as well as ‘none’ can be selected.
Widget root attribute for OGLML developers - Added widgetroot container attribute to allow OGLML developers to prevent separating components defined underneath of a container.
Router plugin off by one correction - The router plugin had an off by one error that has been corrected.
