Also have a question regarding View Control. Am having trouble correctly lining up the display from Dashboard with the video windows from the Carbonite Multiviewer. Am just using a straight BM HDMI>SDI converter and I just can’t seem to adjust the Dashboard ViewControl Window correctly to line up - is there something I’m missing or does the converting system I’m using need more functionality (i.e a little bit of scaling?) The Mutiviewer windows are approximately in the right place but it seems as if I could get rid of the Dashboard Menu tab then it would fit…this seems like something really basic that I’m missing. Can you help?(Edit: just found my mistake. Disregard this post…)
For those that would like an answer you need to go into Full Screen mode from the menu bar or by pressing Shift+F11
Is there a users guide for VC?
Hi John,
It is in the manuals.
http://www.rossvideo.com/production-switchers/carbonite/
Follow the link above and then on the right side click on the download for the manuals. Setup and Ops manuals have sections for ViewControl.
