Is there anyway to adjust the the H and V phases in the output of the Vision switch?
I am running Vision software 12.1a
Hi John,
No the Vision Output is locked in relation to the incoming Reference Input.
If you want to be able to swing the output you will need to add a Frame Sync downstream of the switcher
